As a rule I always reseal my forks off season, so I have no surprises in season. I will do this with KYB stuff, but was just questioning if there was an improvement in stiction that made doing it sooner rather than later. I do not doubt the stock stuff is durable, and stiction is vastly reduced with seal grease under the wiper. They are really only bad after the bike sits for awhile.
Good stuff in this thread. I wish to add my $.02 worth, if you all will indulge me.
I've found that many bikes of different brands suffer "stiction" in the fork action after sitting for a while.
My theory is that the upper lip of the seal will dry somewhat, and the stiction is the result of that loss of lubrication.
Glenn,
I see that you use seal grease under the wiper for this condition.
My favorite remedy is to cut a 1/4" diameter "string" of air filter material and saturate it in fork oil; and then place it between the fork seal and the wiper.
This gives lubrication after the bike has been sitting for a while, and also tends to catch any dust and grit that gets by the wiper; temporarily keeping it out of the oil seal.
When cleaning the bike after an extremely nasty ride, it's easy to pull the wiper, and clean and re-oil the air filter material "string".
Up through the time it was stolen (June 22), my '06 with the 'Zoke 45 Shivers never had a seal leak, or even weep. That was 4 years on the original seals and almost 3 years on the set installed when I had them modified. (I received the 2006 DE300 on Sept 1, 2005.)
Good Riding and Suspension Tuning to You All!
Jim
