Colemanian
"Gasser" is how I refer to mine most of the time
Should of known. I've seen it several times already.
The other thing I'd like to do is replace the dinky chain rollers with some good ball bearing replacements. I seem to find a design feature I really like, then I find something like this that makes me scratch my head.
I've still got a few bugs to work out on the suspension. It's wired, if I would hit one square edge, it would soak it up. But if I would hit multiple objects, like some hard braking bumps, it would pogo my brains out. I think I needed more rebound across the board and a little less compression. The motor impressed me to no end. It would lug way down low and stay running.
Well it's been a couple months now and there are a few things I've noticed. The first is, I love this bike. It's a head turner, around my area few people have much experiance with gg so I like that part. It's been super reliable. No mechanical problems. The suspension has settled nicely, it seems to ride really smooth at a cruising pace, but the shock "packs" a little when you pick up the pace in a whooped out section. Of course, the maneuverability is great. It gives me a ton of confidence in the tight stuff. I've never been able to have factory width bars where I ride, but the renthals remain uncut. Just a quick flick of the bars and youre dodging through the trees.
The ONLY real complaint I have is the carb. I can't seem to get the thing quite right. I ride mainly in the lower rpms. Most of the time I'm in third or even forth. But occasionally I need to get on the pipe, like on a long hill, or entering an open stretch. The bike bogs a little when transitioning from the pilot to the main. Then it cleans out and rockets forward. If I ride it harder it doesn't load up on me, but it's very tiring to ride a 300 on the pipe for very long.
I know this isn't the bikes fault, I just need to spend more time jetting. It doesn't help that our weather changes so rapidly here. High on Monday was 70 low on Thursday was 9!!! Crazy huh
Another thing I just remembered is my decal/grafics are peeling pretty bad. My front fender and radiator shrouds pull free when I pressure wash it. None of my other bikes have had this issue. I'm sure it has to do with all the edges and points this thing has. Other than that I have no complaints.
Pick up a can of 3M super 77 for those graphics. Clean the plastic and back of the graphics with some brake clean and re-glue.
