Went and rode the test track again today with the new suspension settings.
The first few laps were spent trying to dial in the rear shock, in the end surprisingly I ended up using almost the same clicker settings as what I did with the 6.0, although I'm further in with the LSC, running about 4-5 clicks out on LSC now, seems to offer the best balance of keeping it up in the stroke at the same time as allowing some squat to grip when needed. Rebond is the same as what I used with the 6.0, it's a very fine line at the moment between letting it rebound quick enough not to skip over the acceleration bumps on the track to then not pushing on off camber and slippery rocks. No doubt when I next ride a rock garden I'll wind the rebound in a few clicks...
Now the forks, my goal today was to dial in the clickers to where I was happiest with them, then play with the PFP to get a feel for it and see if I could use it to keep the forks up in the stroke whilst being able to wind off the comp clicker.
The rain storms interrupted my testing so I didn't get a chance to do much apart from get the clickers close. The new rebound stack worked well, the clickers are now at 10-11 out (they were at 1), and while I could add a click or two they are close.
The comp clicker is still pretty far in, about 4-5 now, any further in and it stays too high in the stroke and starts deflecting on trail trash. But they are pretty good where they are.
What is much improved is the forks blowing through the stroke and bottoming out, it still happens on the sections where it was doing it in the video that started this thread, but not as often and not as bad. Whether it was the extra shim or increasing the outer oil level to 350mm I don't know, but its better.
No video today as I was on my own, no camera man to film me
