Motosportz
I got the bike running pretty well yesterday, but then today I found it really hard to start. The hardest its ever been (excess of 10 kicks). Usually its a 1 kick fire, if not second. Always has been with the PWK and the Lectron. I'm not sure why, as when I first installed it, it was well on the lean side and still fired 2nd kick on the choke, which raced away at idle and continued to race once off. I brought it around 10 clicks richer from here to get the idle to settle in and give good response off the bottom.
Once I rode it for a bit today and noticed a hanging idle present so went a couple clicks richer. I've hit my first real issue and its one I was honestly expecting to have to get through too. I have a lean bog off idle, yet a rich condition at idle. Getting the 1/8th -1/4 throttle rich enough to not bog leaves me with excessive blubbering up to that point. In PWK terms its like the needle diameter is too lean. From 1/4 throttle on it runs well, but feels a bit rich too. I can't lean the mid out without the below 1/4 throttle losing all its torque. Its kind of the same thing that happened with the Lectrons metering rod too, but the compromise didn't seem as bad. Ie the Lectron didn't seem to hang its idle as easily, or drop its torque so much, or even burble as much off idle.
I think the Lectron rod I've been using more like a small pilot, with a thick needle, and leaning the needle clip enough to clean the bottom end would leave the midrange lean..
Where the APT one feels like a large pilot, lean diameter, and a richer needle(or clip position). Richening the needle clip position to fill in the lower throttle only makes the mid richer.
I also found I really have to rotate the carb around a bit to clear the chain. Will this cause any flooding issues? I've always ran my carbs with the float seam parallel to the ground, which I had but there is already minor signs of the chain making contact and thats just in my play loop.
So initial results aren't what I expected.. but I have emailed APT and also let them know I'll be posting here. Maybe Corey will chime in with some ideas. I'm not shunning either product, but I think that the Australian conditions/requirements are clearly a bit different to those in the states. I always found that when comparing my 250F settings to those on thumpertalk too.
Will be interesting to see where you get with it. Yes your guys fuel and air seems a good bit different than ours int he States and requires different setups. I have even seen this on the JD EFI tuners I sell. The Stock settings are way too rich for some reason but work perfect here.
(Warning, going to talk about Lectrons carbs now, turn off your computer :>) the idea of one rod covering everything and no adjustable powerjet like the Lectron has makes me uncomfortable. The APT I had did run very good on both a 125 and 165 husky but I was 30 turns of the adjuster different than John who I got the carb to try from. there was a slight bit of leanness in the mid that I could not get out. Still ran far better than a jetted carb but was scratching my head how to solve that last 10% I wanted to fix.
With a Lecton and 40 years of experience and rod design that have piles of solutions for this stuff. It would be EZ for you to choose a lean low and, medium mid and then dial the top to your liking via the powerjet. I like this setup and it allowed me to take the Lectron that I loved as is but was 90% perfect and tweak the last 10% out of it with a rod and shorter PJ pickup tube. Lots of options with that carb. Since doing so I don't even look down at the carb it runs so freaking perfect. I have never been to a point where i did not want to tweak something on a carb always chasing that last 10%, I am there now. The idea of a one rod, no powerjet works on every bike carb sounds wonderful. Time will tell if it is a reality. I think as they have more feedback they will also have many rods to offer and maybe an adjustable powerjet too at which point will simply be a Lectron copy. Might be wrong but I have 6 months of intensive experience with this carb now and think thats going to be the case. I have sold over 75 of these Lectrons and have piles of feedback. I also have several fast buddies local running them who i feed parts to in the name of research. Buddy Jake just smoked his class at the ISDE this last weekend on a basically stock husky 125 with a Lectron on it.
Look forward to your feedback and solution to this.
Simple to fix. First off if it was lean bottom and mid simply turn the rod in a few turns and it should make the bottom and mid richer, then dial the PJ for top. Did you do this? What did it not fix? If that does not get the results you want run a 4-1 or 4-2 rod (richer bottom and mid) instead of a 3-1 rod (or my custom rod which time will tell but might just become the defacto rod for single cylinder 2 stroke dirt bikes) and set the bottom and mid. Then dial the PJ for your top end needs. If the PJ runs over the mid to much and makes it to rich get the shorter PJ tube which makes it come on later in the throttle. Then you will have perfect bottom, mid and top, great starting and smooth idle.
