I'm happy with the tubeliss setup. The only issues have been 1) high pressure tube needs watching as it bleeds down gradually and 2) takes a lot of weight to balance. I would prefer the high pressure stem and low pressure stem to be 180* apart.
Thats...pretty bold Fred...... I like your thinking here! Tires are not cheap.... I have been on the fence about this system....seems like where I would use a soft compound (Mich XC12 S), I could get away with a (MX51 or Mich XC12M?)
I will cut a old heavy duty tube down the middle (cut out valve stem) and use it as protective liner as add protection then install a really light weight tube..
to help combat pinch flats in the rocks.
With the TuBliss system it seems like this would not be required?
Thanks
Interesting ... this possibly explains why my front feels like it is bouncing along on the tar, how do you go about balancing a tire?
Traction- YES I get trials tire traction from a knobby without the things I disliked about a trials tire.
Feel- YES It is lighter and it can be felt, I've ran TuBliss and then bought my current bike that had HD tubes when I bought it...I'm tight (broke) so I ran the tires out and I could tell a considerable difference when I mounted TuBliss on tire change over + with the lower pressure there is a grip difference in the front as well
One issue I had when originally changing over was that you need to run 'tougher' tires- on the same course with tubes & MX51s they worked fine with tubes but with the TuBliss & MX51s the grip was so improved that I pulled knobs out of the carcass- you could stick your thumb in the hole and I ran 2 hours on that flat. Problem stopped when I moved to stiffer tires + you don't have to buy top dollar tires, I get great traction/wear from Sedona tires at much less cost
So big improvements in unsprung weight are the real catch here. Along with some improvements in traction. I haven't had any traction issues with the MX51 at lower pressures 8-12psi depending on terrain and pace. I have also managed to rip entire knobs out of the rear and tear side lugs from the fronts. Usually when running too low a pressure for the terrain. Love the tyres and the combo I'm running though. Not sure if it would be worth the effort and coin to make the change and then find a tyre I'm happy with again. I'll wait for Trev to report back
The difference is that your 8psi on tubliss is your upper limit, I know guys that regularly run 4psi on the backSo big improvements in unsprung weight are the real catch here. Along with some improvements in traction. I haven't had any traction issues with the MX51 at lower pressures 8-12psi depending on terrain and pace. I have also managed to rip entire knobs out of the rear and tear side lugs from the fronts. Usually when running too low a pressure for the terrain. Love the tyres and the combo I'm running though. Not sure if it would be worth the effort and coin to make the change and then find a tyre I'm happy with again. I'll wait for Trev to report back
There is often a fear of the unknown. This side of the world the shops also don't recommend it because they have had issues fitting it ... the best I had was from my local ktm dealer who said it didn't work. I later discovered that the the reason was that "since he was riding enduro and not mx" he was not pumping the inner to 100psiWell good god what an ordeal getting these friggin things. I have a new set of rims coming so I don't have to take the trelleborgs off and need rubber for a race in a week so I had to go with tubes. Maybe first tire change ill buy a set. Tubliss does not seem to be very popular around here from what the shops are telling me.
