adv rider
I'm in Boise, and might have my awesome13 up for sale soon!
My friend won't be ready until around sept. , or so. And he's really cheap, so will be looking for a budget priced one.
I discovered that I've kept putting the linkage bearings off for a bit too long.
The swingarm sets (sealed with o-ring) are in great shape.. some fresh grease and all is well!
The linkage sets that GG used normal lipped seals on are wasted. Will need new bushes and bearings. The seals had no lips left and fell apart on removal. I'll be reinstalling them with O-rings I think! (or both).
Some years, the GG bikes came with seals. Later years (early 2000s), they often came with o-rings.
I always install the seals in the swingarm and linkages with the opening to the outside. I feel that this does a better job of keeping the mud and debris out (instead of primarily keeping the grease in.)
Quite often, I install an oring into the outward facing open cavity of the seal. This has worked best for me over the last 19 years.
Thanks Jim,
Any issues removing the seals once installed backwards to maintain? I would guess you don't have to as the o ring will keep the dirt away from the seal so it should be as easy as wiping them out and repacking with fresh grease, once pushing the bush out.
I use a mix of wheel bearing grease and anti-seize (about 80:20) in all my linkage and swingarm bearings. I also pack the gap between the axle seal and wheel bearings with this same mix. After every wash, or ride that was full of water crossings, I give a shot of WD40 to every pivot point/axle seal.
I check on the lower shock mount every 50-75 hrs, as it's the canary in the coal mine for linkage maintenance. If the lube in it is still good, everything else is still good.
Never had a bearing go bad with this method. Never have had to replace wheel bearings.
That looks like a 2017!
I was drooling over that new 2017 Gasser, I want that adjustable PV!!! If only the stickers were as 2014 racing model, I just love 'em!Yes, it certainly IS a 2017.
My own bike was used on the same event by a young lady. She actually won hobby class in front of 43 men .
Can't argue, she is a very talented girl, I saw her pull right past me just before the finish line I think she was the only one in beginners class who did the extreme test?
