Proper compression test- THROTTLE WIDE OPEN- kick the engine several times....at least 5 times, some will say kick until the needle stops moving
I have performed many compression tests over the years as i restore classic cars for a hobby. I tested it 3 times because of the results. The last test i even removed the gas tank to make sure i was getting a seal. I even tested the gauge through my compressor after i finished and it is reading true.
Surely you'd feel the lack of compression under foot with only 30psi too.
if you have spark then the problem isn't the kill switch wires (they kill the spark) and won't be any other wire issues either. Keyway is a good clue it isn't a timing issue.
The only other thing is fuel/compression.
Is the plug getting wet after you have been trying to start it? Not wet = no fuel.
If the plug isn't wet try laying the bike on its side until fuel dribbles from the overflow then try to start it.
Next is to check the rings to see if they have stuck. My kid burned his rings (polite way to say he melted things) and the bike still felt like it had compression when trying to start it but wouldn't even pop.
It is "resistance to turnover," doesn't matter if it's friction or compression. Hard to kick is hard to kick.
Wow. It is what it is obviously, but that was a strange set of circumstances. Running one minute and then not restarting.
Is it odd to have 8 to 12 ounces of oil pour out of your pipe when you remove it. After disassembling the bike to rebuild the engine, i was cleaning parts and when i got to the pipe a good 8 to 12 ounces of oil had been sitting in the bend of the pipe for who knows how long.
In my experience, the oil is left over from previous starting attempts that resulted in a flooded condition. As the oil doesn't burn, it just gets pumped through the engine until it reaches the lowest point of the system, usually the expansion chamber. The oil also prevents the engine from starting or running, as it effectively plugs up the system. Similar to stuffing a rag in the silencer.
So, yes, that is odd.
So, I got around to unpacking the silencer today and this was the result below. The packing was dripping in oil and when i removed the old packing the perforated inner tube is completely clogged with carbon, not just covered in oil but clogged. I am having to poke each little hole with a sharp object to break the carbon off. Might just buy a new one. Thank god i bought this bike so cheap.
.....a good 8 to 12 ounces of oil had been sitting in the bend of the pipe.....
