Corey when you said " GasGas will be the first to benefit" does that mean they will be comming from the factory with the SmartCarbs?.
Is the 38mm cast carb a good candidate for an 1983 RM250 ?
stock is a 36mm Mikuni flat slide. Is the cast 38 too much carb for it ? The engine has been extensively ported etc.
Thanks Corey, I just placed a preorder for a cast 38mm carb.
If it works as well as I'm expecting I'll be ordering one for my Gas Gas too
Barry
I would like to see a size for the kdx also.![]()
The kdx has more size constraints since it originally came with a pwk33-35.
My son must have been bored today and decided to put my SmartCarb on his 2011 TM 250 MX. The bike fired on the first kick as he didn't dump the fuel in the bowl. After a few clicks leaner the bike which was already a rocket is now much smoother, better throttle response, and much cleaner pull than the RB worked over carb. He thought before the ride it couldn't get much better than the RB unit he has. He is now going to order up his own SmartCarb.
