I asked about the flooding when this thread first started and Corey had told us about the addition of check valves to the next batch of billet and cast. That is why a lot of us have waited
I believe the wait is worth it.
The prototype overflow valves are working very well and provide a nearly fully contained fuel system, which is pretty cool for a carburetor. Here's what testing has showed so far:
In the event the floats stick open, the check valves shut the vent lines immediately and then the only fuel that can enter the engine is through the nozzle (jet size orifice throttle shut) and is a 97% reduction in fuel flow compared to the vents being open. We've been toying with the idea of reviving Grose Jet fuel inlet valve technology (if permissible as no one seems to building them) it's a lot like our overflow valves in technology and would be a good fit. Likely then any float leaking issues would be vastly diminished.
The overflows are very fast reacting valves, so little to no fuel can enter the engine during a tip over, roll over or upside down; the bike can be dropped and will continue to run indefinitely, depending on angle, if over center far enough to shut the floats then it will run until the bowl runs dry. If upside down it will quit running because the nozzle is no longer in the fuel. A full on crash we haven't accomplished just yet, but give me time....
http://www.flickr.com/photos/89546082@N08/8398639070/in/photostream
Once the bike is dropped and lays there long enough to die it will start easily in one or two kicks, usually without opening the throttle, clears up easily and your off and rocking.
A couple of things we have to do yet. Several retro fit billets are going to our GasGas racers for review and altitude testing, patent paperwork/submission and a little better parts pricing search. This should all come together about the same time the new billets show up at the end of the month. We're now really close guys and there will be a retro-fit version for our existing billets, a slightly different (shorter) version for the new billets and finally the valves will be fully incorporated into the float area on the cast versions.
BTW the cast carbs are coming along nicely too and different sizes may become available sooner if our new vendor works out. Corey
