So The check valve install took on time @ all,and figured Id remove the bowl
to have a look see. Glad I did The material I used to seal the bowl from leaking
was every were. I used toyota seal packing#00295-00103. Does anyone
know of a sealant for gas? Thanks.
Hi John, I sent you an email too.
We use Permatex 82194 Ultra gray. It's impervious to gasoline and oil. The only place necessary is the three way area where the carb bodies and bowl come together.
