Thanks for the pics jake , out of interest what sort of money do the excavator drivers earn in those mines .
No idea (depends on contracts).. but most would easily be on minimum of 100G a year for week on week off fly in fly out, driving trucks.. 12 hr days.
You would probably like that deal half the time.
I can't seem to start my morning without my daily Jakobi-SmartCarb Update.
APT should be paying you folks handsomely for all the R&D y'all been doin' fer 'em.![]()
Awesome he really seems to battle with throttle/clutch control and getting the power down!Turning a few knobs and possibly a float adjustment is hardly what I would call R&D. What we have here are mostly people who like to fiddle with things anyway, but we strive for truly plug and play. I believe Jakobi may have a flawed metering rod and have him a new one on the way. We now have several hundred billets around the world and our win/loss column is decidedly in favor of the win side. We have less than 2% that have had problems, not bad for a beta version. We have more customers that are not posting on the forums than are. I wish they would because some of them have some pretty interesting things to say. Did I mention Graham Jarvis has a 36mm on the way?![]()
What I like most of the APt Carb is that the carb acts the same every time I'm out. If the bike was running rich one ride, the next ride (even if a few weeks has passed) the bike still runs rich. The weather does not affect the carb.
I was also wondering how much of the inconsistancy I am getting is due to the spring binding and hooking sometimes. I noticed last ride it would sometimes be notchty at the lower settings, and other times pull smoothly.
Well it seems KTMTalk has shut us off for some reason. There were several questions over there that I was hoping to answer. Please ask those questions here and I will try to reply. Corey
@Corey: Which area is influence the most by changing the float level ? For example if I lower the float level a bit would it lean out more at idle or near half throttle?
@Liz: I sent an e-mail with a request for some spare parts last week - haven't gotten a response yet. What would be the best way to order those parts?
Quite right, you're always welcome here no matter what you ride. . .Well, I seriously hope I'm welcome here both by the GG guys and Corey. Anyways, here is what my last q's were:
Michael
Michael
I have to admit I have been lurking here since the introduction of the new generation GG, but have been scared away by the almost mandatory (seemed like it) bashing of other brands before even getting to post GG infos.
Anyways, I haven't played with the float level on the SC yet since mine also seemed to be at 20mm every time I checked, but infos posted on that topic seem contradictory. MikeS and his testing with the Grose Jet indicated that float level is important as did some other posts with levels ranging from 17-19mm to fix a lean mid. A statement from APT was that float level would be less important. So I guess I have to see myself.
When testing the float level I noticed that you have to be careful when filling up an empty float bowl. Open the fuel valve too quick and the sudden raise in pressure within the float bowl will close the tip-over valves causing an air pocket inside. This air pocket will keep the floats from closing the float valve, the fuel will continue to flow and exit through the needle jet (metering tube or however you want to call it). This could be misunderstood as sticking floats/float valve which it is not. Just sayin.
Last but not least - did anyone notice the SC going crazy (rich) with a high vacuum just after idle. For example if you are coasting on a road in a high gear with almost no load on it and cracking open the throttle just the tiniest bit to keep the speed it will run extremely rich - impossible to ride with a constant speed there and pretty annoying on transfer sections on the pavement (= 80km/h 6th gear on a KTM 300). As soon as there is a little slope or head wind this effect is gone.
Michael
Also from drehwurm - @those who would like a correction circuit (air or fuel) at the idle area for their SC: KTM part# "81241060000 STARTER VALVE COMP" and a M12x1 fine thread pitch metric tap could be your solution. The starter valve is the adjustable hot start/idle air bypass of the older SXF throttle bodies which fits the SC perfectly except for the mounting thread. Depending if you disable the choke fuel jet or leave it enabled you could create an additional air (like an air screw on the PWK) or fuel (like the 4-stroke carb fuel screw) bypass to change the mixture of the SC at the idle area. It works on the EFI throttle bodies so why shouldn't it on the SC (at least the air side). Worst case, it doesn't work you just use it as a choke like the stock setup on the SC.
We had contemplated trying this with the Lectron and after some research actually found a kit available which even indicated the correct size and placement of the hole. Never got around to trying it. Really as you add more circuits to them you are just increasing the complexity of the carb again, and I think its the simplicity that appeals to a lot of the market more than "perfect" jetting. When you also consider how easy they are to get in the ballpark, and how much smoother and consistent they are over a stock jetted PWK they really sound good.
I'm also curious to hear about the float height adjustment. I haven't had my carb back out to confirm the float height since installation, but at the time it was set at 20mm from the top. I haven't appeared to experience any flooding that I can tell.
These will be available as a trade out to anyone who is struggling getting the low speed setting right, based on a flawed metering rod.
There is no need for an idle correction circuit (or any other circuit) if the metering rod is accurate (and perfect jetting) and is a step in the wrong direction. In fact you are then just weakening the signal at the metering rod. Which will require you to raise the needle to make up fuel flow due to the diminished signal. Affecting both economy and emissions.
