Sure wish mine worked well. I have a crap load of time spent on it and it has become a $1000 conversation piece on my work bench.
That article shows that they did 4 runs on the PWK, but never mentions if they actually made any changes to improve the running of the PWK. Who's to say their baseline was achieving max power?
When we get ready to do testing like this, we set up the Keihin's for current conditions. We do the tuning primarily based off exhaust temps that we see for that day and peak HP. Idle, mid and top. For yesterday we were 75f. 30.12 in.hg steady and 67% humidity.
Stock 2009 KTM 300 XC
The 38mm ASII was set with a 170 main jet, N3CJ needle 5th clip position, 38 pilot, air screw 1.5 turns out.
The 36mm ASII was set 168 main jet N2ZW needle 4th clip position, 38 pilot, air screw 1.75 turns out. The SC's we used factory settings.
Power valve settings for all tests were; green spring half a turn in.
You will note that the 38mm Keihin builds almost identical power as the 36mm SC on this bike. I've been cautious with posting our own in house dyno charts but theses tests from yesterday show what DirtRider was saying. They also reported they were using KTM recommended settings and listed them in the article.
The "jetting" changing throughout the day makes me wonder if you have a sticking vent valve (if I understand the design correctly). I. E. you are not getting the air density correction that you should be getting as the conditions change throughout the day.
I can tell you right now from memory that there is some definite play in the D washer. Not 45 degrees, but enough that the MR can turn a bit to each side. I know this because I wondered about it when I had the MR out for the lapping. Thought to myself "thats a bit of a sloppy finish". Issue being I don't have access to milling machinery to make up my own. Its very possible it has rotated a bit during running, especially after making an adjustment.
Last time I checked my pipe does not have a EGT fitting....no dog in this fight for me...yet.....Isn't EGT monitor a advantage?
My buddy runs shifter carts and EGT monitoring plays a pretty vital role in jetting for him.
Please expand on this subject.....
THANKS
Customer service has not been the problem. The promise of a bolt on perfectly jetted carb that has been anything but is the problem.Thought we agreed to buy it back from you, replace it, or work it out.
Is it not what you said or did you change your mind?
I said it. But was not asked to be quoted on their web site, and was not treated nice by them so don't care to participate. Not a big deal just don't want the association. The APT I tried was fine and I was honest in my reporting which can be found here and at Cafehusky. I moved on and do not endorse this product now as I found better products and support. No big deal. Was looking up something else, saw my quote there and found it funny after the owner publicly trashed me and called me names.
Quote will be removed. Kelly no one trashed you or called you names, publicly or otherwise, I appreciated your review then and I appreciate it now, it was Cafehusky's unwillingness to post my answers to peoples questions regarding the SC. I'm sure you're way past it, as am I, but the conversation is all written down in the forum threads so you may want to keep your story straight.
I can jet a carb perfectly well. I do it every day for my customers. The idea was that I would never have to mess with mine no matter where I rode.
I,like you don't always have time for my toys. I'm not pissed off, just disappointed.
