I have seen the exact same symptoms before I got my rod/nozzle sorted. One thing you can try is to go in really far with the slide stop till there comes a point where the RPMs finally react to the slide height and work from there.
Michael
Basically what I have done Michael. I backed the adjuster right off to nothing. Rode the bike until it came up to temp and then started dialling it until the bike just ticks over. At this point one click richer on the MR is enough to flame it out and take the idle away.
A leaky float valve can deffinately give you those symptoms. If you set the idle high enough so it will idle consistently for a period of time well then it is too high after you run it at higher rpm's. This will give the bike a lean feeling when coming down from higher rpm's. You might try shutting the gas off while it is idling and see what kind of feed back you get. I know this is stuff you already know, but sometimes a guy gets so rapped up in a problem that we forget to try some of the simple things.
Thanks rosco. Appreciate the thoughts. The inconsistancy is what makes me think it might be float related. I've always set my bikes up for the lowest slide height possible. It makes for good signal when starting, punchy response off idle, reduces the chance of hanging idle, and more so I found you don't get the pipe bang with a nice low slide.
This to me based on my Lectron experience is caused from to rich rod at the initial setting. If the slide opening is about typical for a good idle yet you cant change the idle much it is rich. If the idle if erratic and sensitive it is lean. This is a slide to rod position thing. Lectron tells me it is this critical area, at idle and just off idle, that is the most important part of the rod profile. The super small slide opening, high velocity, and super small opening at the base of the rod is very sensitive to this setting. The issue if you don't have the rod profile super dialed you can get the bike to idle nice but might have a huge bog as it is lean all of a sudden when you open the slide. If the rod profile is not spot on you have inconsistencies and cant get both a good idle and good bottom end. As you have found from sanding the rod, taking .0001 off can make a difference. This shows the rod profiles on these are very critical. They like lean at idle but need to ramp up to rich pretty quick right after that so no bog or soft bottom end. Sounds like your rod does not have the profile to support the needed lean idle AND ramp up so you have good bottom. You have dialed it so it runs good and has good torque (rich) but this is making it run erratic at idle.
How does it start hot? Do you need your choke when cold or no?
Starts on the choke when cold. Starts easy when hot. Like in gear easy. No issues with the starting or the idle mix. The bike won't idle well off choke when cold for the first 30 secs, and loads up and won't take revs on choke when hot. Everything is as it should be.
I know I have a very small lean spot just off idle. Very small think 1/8th turn Air Screw small. And then the bike runs very well through the revs and if anything is probably a touch rich towards WOT.
I had got some hanging idle issues on run down from high rpms, but I'm also getting some spooge at the tip of the silencer which I hadn't experienced before, so I may have taken a bit too much off towards the end of the MR.
I guess what I was trying to highlight is that the slide height has a substantial effect on the lower openings. Lifting it 2 turns say, will most definitely lean the bottom end out and cause a hanging idle. You can then tune it back into the range again moving the MR richer which adds fuel right across the range. Having the slide up so high though then conflicts with the inital ramp up, and as you say leavs it hanging lean too long and torque off idle is lost. Lower slide and a leaner MR position gives the great response but hanging idle on decel.
Its almost got me beat. Few more tricks to try yet; nozzles and orientation of the MR. Double checking the floats and needle for any signs of hanging or binding. Corey states they have encountered issues with sticking check valves, generally in humid conditions (I live in rainforest - Right now 8am 76%RH and 21C). I also suspect that the inconsistancy (inc hanging idle) may be the result of an air leak. Now what could cause an intermittent air leak? A bad seal somewhere? Like... the seal on the clicer mechanism? Thats what I'm thinking and going to focus on today. I'm not sure how it seals but I assume it will be an o-ring. I've noticed after pressing the clicker adjuster in, and making an adjustment it doesn't spring right back to the top and I guess its possible that in some instances I haven't pulled it back up and air has been able to sneak back past the o-ring.
