I bought the Motion Pro 10-3000 and can't get any free play in the cable at all. Did I get the wrong cable?
I haven't started it yet.
I was referring to the actual brass receiver fitting on the carb, not the cable...straight on both ends . no 45's
OK, I'm convinced that I have the wrong cable (although it was labelled 10-3000). I need something longer... The slide is definitely not closing all the way. Not even close. Photos show the cable attached to the carb. Adjusters are in all the way on both ends. One of the slide with cable attached. One showing how far the slide is open with cable attached...
EDIT--- I went on the Motion Pro website. Cable housing length for the 10-3000 is 41.73 inches, which I have. Measuring exposed cable on my OEM cable (while attached to the OEM carb with slide closed) is 2.75 inches. Exposed cable on the Motion Pro (while attached to SmartCarb with slide closed) is 2.05 inches.
Any thoughts or recommendations?
Thanks Corey.Several things. You will want to unscrew the brass cable guide out that came with the cap. Screw the threaded end of the motion-pro cable into the threads in the cap, all the way down until it is snug against the lock nut. Then you will want to file or sand the end of the cable nub so it will go in all the way flush with the retaining area on the slide. You shouldn't be able to see the cable end hanging out. Do those things and I'm sure you will have enough cable.
Best,
Corey
This was the fix! Thanks!Several things. You will want to unscrew the brass cable guide out that came with the cap. Screw the threaded end of the motion-pro cable into the threads in the cap, all the way down until it is snug against the lock nut. Then you will want to file or sand the end of the cable nub so it will go in all the way flush with the retaining area on the slide. You shouldn't be able to see the cable end hanging out. Do those things and I'm sure you will have enough cable.
Best,
Corey
