twowheels
Active member
Thanks for the invite, Mr. Desert !!![]()
Have you got a fire-breathing 165 with a cast SC too? By all means, come on
I thought you were out of town? If not, then come on? 8:30 MM 4. We are meeting Doug Seitz out there also.
Hey guys Im new here but Im in AZ too and just curious where MM 4 is at? Thanks
Well I am not going to be much help here for the time being. On our way to Arizona we stopped in Laughlin to ride that Sunday afternoon as we weren't going to make it to the mm in time. 8 miles into my initial ride, I caught some air over a rise and missed the trail slightly on the other side right into a barrel cactus and the endo ensued. My entire left leg is swollen up and black, purple, and looks like a rotten sausage. Up until then the SC made serious power but needed quite a bit of adjustment as I was too rich on the bottom. What is great about this carb is the ability to stop, shut off the bike, reach around the tank and adjust in seconds gloves on. I had made several clicks in adjustment before the unfortunate mating with the barrel cactus. What is really encouraging is how well it runs even though it was rich. Pulled amazingly well and ripped. Was getting better with each adjustment. I wasn't able to do any flat out rips through the gears as the area we were riding in is fairly technical.
I still hope to get some time in before I head north.
Aww! Walt sorry to hear that. What can be construed as quite a bit of adjustment though is still very very small. 20+ clicks is still less than one clip setting on a conventional metering rod. I personally like a little leaner setting on the idle, just to where you whack it open there is no stumble. This gives you a lot of gains in fuel economy and a nice clean tip in.
Sorry to read of the wreck. On the up side: better a barrel cacti than a grove of horse crippler!!!
It wasn't the barrel cactus that did the damage it started it with its cement like density and the bars, ground, and my own bike making sure I had good soil contact did the dirty work.
Hope you're healing up Walt! We're all curious to hear how the SC is working for you, but more importantly that you're on the mend.
Sorry for the hijack. I'm moving to Sierra Vista. Where's the closest single track?MM4 is off of hwy74 at mile marker 4. Depending on where in AZ you are? There maybe some riding closer to you?
I am going out again on Thursday to ride? You are welcome to come along? PM me so we don't hi-jack this thread.
Sent from my LG-P999 using Tapatalk 2
