The smell of 2stroke oil is very important but the oil I smell is whatever the guy in front of me uses - Now if I could just get those dudes to use Klotz I'd be happy, happy, happy.I have been having good luck with Klotz R50.It smells great too!
I opened this can-o-worms...once. The lid is still offWhat a mine-field. I almost regret reading all this !
After reading these posts [and other forums over the years] I decided to make a change.
I had great results for many years with Motul 800 [50:1] in my Yamaha. Upon switching to KTM & Gas Gas I began to notice spooge drip line running down the length of the silencer. It was actually worse with my Gassers than the KTM.
Last year I switched to Redline [50:1] and the results were much better but still developed more spooge than I liked. The Motul 800 developed so much that it actually would drip off the silencer onto the swingarm. The Redline mix was better but still dripped about halfway down the silencer and was thick enough to be difficult to clean off.
So, for this last weekends ride I made the switch back to Motul but the 710 [based on some posts here] at the same 50:1 ratio.
After 2.5hrs of a mix of single track and fast double track, I had ZERO spooge running down the silencer.
I will note that I had less "smoke time" on warm up and when hard on the gas out on the trail with the 710 than I did with either the 800 or Redline. Throttle response seemed better and power/torque delivery "felt" stronger.
The "non existent" spooge tells me that it is indeed a "cleaner" burning mix. I will keep an eye on things to make sure that it is the case and not a situation that is actually too lean. I think I will stay with this one for a while since one ride may not be a sufficient test.
FWIW that is my 2 cents.
would you ride semi synth scoot oil, wich has the same specs as other non-scoot oils?
or allways fully synth oil?
i don't really wring the neck off of my 200,but not pampering her either...![]()
Both have very high flashpoints and are great oils if you run a hot engine. Low rpm running and/or rich fuel mixtures will result in much cooler running engine temps which work much better with oils that have a lower flashpoint. A fast guy on a 125 will love these oils but a slow guy on a 300 gasser will smoke like an old diesel and fowl plugs.Motul 800 or Klotz Supertechnoplate- Nothing like the smell of Castor. Both at 50:1![]()
Have any of you used Bel-Ray 2T oils? I am asking as my local dealer has started to stock Bel-Ray rather than Maxima and I haven't seen it mentioned in this thread.
Any of you UK guys (Or anywhere else) use Putolines top offering: MX9 ?
Its pretty expensive at around ?18 ($30), but i did 80 odd miles today with a guy using it in a Husky. He's been using it 3 years, reckons he hardly ever suffers with spooge, and it smelt absolutely DIVINE !
Ive ordered some anyway. Just wondered anyone elses thoughts on it.
Putoline MX9 has a similar flash point to Motul 710. MX9 lists at 78C, and 710 lists at 88C.
So I think as far as spooge is concerned, it will be pretty clean.
For reference, Motul 800 flashes at 252C, and Putoline Racing Oil flashes at 250C.
I have never run MX9 personally, but know a racing family that ran it in many CR125 Husqvarnas with no issues.
