Hello,
I've recently bought a 2011 gasgas 250 4t. I enjoy it very much.
I've found the manuals in the gasgas site, but i need the electric wiring diagram. I'll appreciate the help.
2011 250 4t.
Thank you.
The spanish webiste gasgasmotos.es seems to gave gone again, its redirecting to another site, is there anywhere else I can get a manual?
Hello,
perhaps someone have the workshop manual or the schematics of wire harness for the EC 450 or 515 2008-2010 ?
that's the bike with kokusan denki ecu, not IAW marelli
Best regards
Christian
Hello,
Best regards
Christian
Good morning folks,
My apologies for my first post being of the begging variety but I'm looking for a suitable workshop manual for a 2001 EC300 and non of the old links on the forum seem to be active any more.
But seeing as I'm here now, I should probably introduce myself. The name's Steven, I'm 53 years young and was born and still living in Scotland.
Bike-wise I've currently only got two. A 1997 Ducati 748SP which I've owned since 2000 and this 2001 EC300. Historically, they've virtually all been Italian makes (dunno why - just happened) other than a CB500 and an RMZ250.
I picked up this rebuilt (but poorly running) GasGas last year but I've only just got round to dealing with it in earnest. It came with some bizarre jetting which I returned to stock (still ran rubbish) and then moved up and down the range of jets, but nothing cured it.
Think it may well be an air leak so got a test kit on its way. We'll see what results we get and take it from there.
Thank you in advance.
Send me a private message with your email address, and I will email you a pdf file of a workshop manual that will work with your bike. (It is a 2005/6 workshop manual; the first year that GasGas published one.)
The stock jetting was "motocross style" jetting, which promoted midrange to high rpm running, but didn't promote an engine idling or a smooth transition from low rpm to midrange.
For your bike, with it's Air Striker 1 carburetor (which required richer jetting than the AS 2 carb that came on later models), I would suggest a 42 pilot jet and a 178 main jet, coupled with a jet needle which has a better transition from low end rpms to the midrange rpms. The only jet needle from the GasGas factory that I could make work to my satisfaction was the N1EG. The N1EG is very hard to find, so most owners have moved to either a Yamaha 250 or a Suzuki 250 OEM jet needle listed as "optional" on the various parts breakdown listings. I have used a NEDJ, and lots of owners used a NECW. The various optional jet needles will allow the owner to customize their bike's power delivery as it transitions from low end to mid-range; a critical point in the bike's power delivery if you are doing enduro or trail riding in very tight or very rugged terrain.
If I can assist you in any other quests with the bike, let me know.
Good Riding to You!
Jim Cook
Thanks, I'll PM you my address.
To get it running reasonably well we started with a 35 pilot and worked up to up 55. Didn't have anything bigger in the box of spares that came with the bike but oddly it still felt like going upwards was still going in the right direction. The revs aren't dropping very quickly and they don't remaining very constant. It's very boggy pulling away until what i presume is the main jet taking over and then it's WAHEY! The main was already a 178 so I didn't touch it.
The needle that was in it was an N1EF and nothing wanted to work with that. There was another 3 needles in the box but non were marked. Measured them and they were all the same size. Tried one and whatever size it is (it's thicker than the N1EF) it did improve things.
Do any exploding diagrams exist for EC 250 2008-2009 ?
I cant seem to find any .
