So do they come pretty well set up? I'm confused with the to adjustable jets and is there a lot of adjusting to find that perfect fit? I just want to find something that has this electric throttle response talked about with a perfect idle. Also what is availability on them?
Lectron prides themselves in setting them up for different bikes. They make everything from YZ85 carbs to harley carbs to hill climbers to Alcohol drag sleds.
they come setup very well. Usually need nothing to a few turns of the rod. Very EZ. Mine has been on a husky 125, husky 165 and RM125 and runs perfect on all. My custom rod is simply me wanting to take it to the next level cuz I like to mess with stuff and these little bike with huge carbs like a little different setup. Loved it as is but found it could be improved on and did that. Now i have something to offer over standard setups and like supporting my customers through my findings / testing.
as for the adjustable, the externally adjustable powerjet is just for the top end, the rod does the bottom and mid and some top and you fine tune with the PJ. This allows you to do things like go richer for sand dunes or leaner for extreme altitude changes. Works great.
Available? Yeah for the last 35 years
these guys are fantastic to work with, care a lot, are very quick to make changes as needed. Been a great 4 or so months of working with them. Their single cylinder program has really been focused on great running for the last few years. Real good stuff.
So short answer is yes, carb comes 95% ready to go, slight tweaking might be in order then just ride. I have had, and have, piles of standard carbs and a very nice selection of jets, needles and slides etc. and hope to never have to pop the jet case open again. I for one will never run a jetted carb again if I can help it. I 100% converted. Tossed one on my loaner RM125 for the fun of it and yep, works WAY better than the good working carb on it.
Kelly
