wence
Bronze Level Site Supporter
Just an update,
Spoke to the suspension people that did my forks today and they were very helpful.
The spacer / washer is located at the point where the dampener rod enters the inner cartridge and is meant to be there and meant to be loose as it slides down into a sleeve internally once installed in the outer fork leg.
The reason for only 230-250ml of oil being in the outer tubes is basically because the max they would have put in would be 270 ml depending on what the forks had in them when they opened them up??? I did push this a little further but for some unknown reason they don't put enough oil in there.
The lack of oil caused the clunk and cavitation in my forks and also caused them to have no bottoming resistance.
Not sure why one leg has 16 turns of compression adjustment and the other 24 or why the PFP spring flopped around in one leg and not the other. They said they should both be equal,( obviously they were not).
Hmmmmm
Hmmmmm
