And if someone will mail it to Austalia put me in for a diecast 38mm too!! Why not!
I'm in for a cast 38mm. Maybe we can start an Aussie group buy?
I have a Motion Pro cable with the captured threaded end.
Girard,
I've been trying to follow all the throttle cable issues on Smart Carb thread over on the orange forum. I also read through your Motion Pro cable thread on this Forum.
I'm about to order the Motion Pro KTM T-3 cable PN 10-3000 and want to make sure that it is indeed the cable you have that ended up working with no issues on your Smart Carb (when they finally got you the correct top).
Thanks!
I ended up using my Motionpro t3 cable as the cap on my smart carb was intended for the stock cable so i ended up removing the brass insert out of the cap and running a die through the cable thread to match up to the cap thread and removed the locknut and as it fit no problem i was still short by about 2mm so i ended up hacksawing 2mm of the female threaded end of my domino housing and now fits perfect with just under 2mm of free play.I also ordered up a custom t3 cable that will have 1/2" longer cable length.When ordering they need to know the cable so they can install the proper cap.The cable you mentioned Andoman is indeed the cable i used.
Very impressed indeed.I have it on a ktm 200 and it almost feels like i have the bottom end feel of a 300.Lots more bottom and very smooth feel with excellent over rev.You can definitely pull a higher gear now.As i have had a few minor issues to deal with(fitment,cable length) but worth it in my opinion.As for fuel consumption i'm not sure yet but i do know that people behind me(as they usually are,lol)say there is no sign of smoke coming from my exhaust and absolutely no spooge.Also there has been no signs of knocking ,popping,or farting of any kind no matter what elevation i'm at.Hope this helps and if i get a chance to evaluate my fuel consumption i'll post up but for now i'm having too much fun.
Dave
Girard,
Thanks!
Thanks, but I didn't do much! Actually I think Girard should be thanked for spending the coin and bringing this to our attention.
Thanks for the report Dave. Mine will be here tomorrow according to UPS tracking anyway. Can't wait to try it on my Husky 165 ! Did you have any trouble tuning it for your bike?
No trouble tuning at all and like Girard said it comes really close right out of the box within 1 click lean or rich if at all.A quick note though about cold starting as i went for a ride last night in 29deg temps and the bike wouldn't start even with choke on so after a lot of kicking and cursing i decided to lean the bike over for 1-2 seconds to let some fuel get into the engine and low and behold fired up with the choke on in 3 kicks and ran flawless all night.
