desertgasser300
Banned
Ride 4 fun,
Since you use a PWK carb you should be good to go. Like said, my oem crab is only 76mm overall. Measure your crab to make sure.
Good luck
That is a big crab! I think they make a shampoo for that.
Ride 4 fun,
Good luck
Yep clockwise to richen and counter clockwise to lean. Makes since when you think about it; raise the metering rod for more gas and lower for less. I can adjust mine without getting off the bike.
Diggs, I've had problems w/ mine showing signs of leakage. mine were @ the bowl though. Aaron @ APT said to clean it up and use a compound sealant.
I tryed adj. the float level a dozen times. No matter how low the level was
it still leaked!!! Thats when I used the sealant reluctantly. I a little spooked @
yours leaking @ the vertical joint? Keep us posted.
Correct I don't have the 12 or even a GG at this time. My SC is mounted up on my 08 CR165 Husky. I could see it being tight on a new GG though. On turning the adjuster I've found if you press it down first as instructed and then open the throttle you kinda turn the adjuster and slightly play with the throttle position until you feel it engage then the clcks are smooth and you and feel them as the click. Not applying to much throttle pressure works for me.
thanks , i checked the impeller when i put the new piston in and all was good , only rode twice since , it was doing it from cold too , i tried putting the soft power map on and it wasnt so bad .Also check your water pump impeller. They are back to using plastic again. Mine was dragging on the cover and could (would?) have failed if I didn't catch it. Cover casting was bad as well.
This was not uncommon some years back, and why Les at LTR started to mfg alloy impellers. GG went to alloy in '05 as well, now back to the same old parts that failed ten yrs ago. I could understand a new design/materials, but I have older ones and this is the same exact part.
Maybe swap your PWK back in for a ride to isolate it as a Smartcarb issue.
i did a compression check last night on my cheapy guage and it read 180 psi ,how does that sound ?. i also talked to my pal who knows his stuff and he says its running rich , which explains why it gets worse the higher you go .
hey jake , i do like the carb , when it runs well it runs great , i just need to iron out a few little niggles the same as with any other carb , my problem has been lack of time and iv only been out 3 times since i bought it so im still in the setting up phase , its a bit hard to start playing with setting when your out trailriding and you have a lot of ground to cover with a group .
im going to get some fresh fuel later and go out on my own for an hour or two and see if i can iron out the small problems i have .
the only problem i have with the carb is the dumping of the fuel into the cylinder , but there will be a fix for that very soon i hope![]()
