How was it changing those ttx seals Fred?
Put on a set of protaper contour Wyndham bend that I had filled with foam.. .
Why's that? Does it help with vibration?
Started putting mine back together today. Put a huge order into the Motocross Center as well today![]()
Yes. It's an old trick but actually helps with vibration dampening.
I've put 10 litres of gas thru the bike since mounting the studded tires,all looks good, the tap cons have lost the blue paint is the only thing I've noticed . The sheet metal screws in the rear edge knobbys are still holding . I thought I might lose some of them but I imagine they're not taking much torque. Screws in front also all good. Worse thing is getting it mounted, the nuts imbedded in the knobby seems to make the tire pinch tight at the bead.Saw that stud setup on youtube .Anyone else done it yet. Curious as to how well they hold up?
Cool white frame. Would like to see more pics when it is put back together.
