I just received a recall gasket kit for my estart. The starter would only engage 50% of the time. Has anyone installed this kit? It comes with three gaskets. Do you just measure the distance from the case to the end of the flywheel teeth? The instructions show a range of distance as follows
I assume this is in millimeters as the instructions don't specify the measurement unit and the gaskets aren't numbered.)
1. X < 35.7 use 1 gasket ME250544004-3
2. 35.7 < X < 36 use 1 gasket ME250544004
3. 36 < X < 36.3 use gasket ME250544004-8
4. X > 36.3 use 2 gaskets ME250544004-8 and ME250544004-3.
My gap is 20MM, so I need to install the thinest gasket in the set(ME250544004-3)? Is that correct?
