Jakobi
Buy the race and get the zoke 48mm and I have heard that the IMS 4 stroke tank works.
Don't think its offered in Australia and if it is it'll be about 3G more. Thats some expensive forks.
I wonder how tight the squish dimmensions are stock?
Mine is about .090". Been thinking about talking to Ron about it, the bowl looks about like a gasser does once Ron has worked his magic on it. I might just chuck the head in the lathe and set it at .050".
I'm very happy with the bike so far. There is nothing that turns as well as a gasser but the beta is close.
You took my $$ and bought a Beta?!?!![]()
Wow. That's saying somethin'. Have U fiddled with the adjustable powervalve?
Raced an hour and forty-five minutes on a half sandy, half frozen hare scramble track - had gas left over. I want to pour it out and measure, but by the sight down the tank method, I'd estimate almost a half gallon. Fork was harsh on sharp squared edged holes formed where the frost broke out of the sand, but the rear seemed fine, although I need stiffer springs at both ends as I'm 190 lbs in riding skins.
Power delivery is great, linear, smooth, however you want to label it. Hooking up on black frozen polished dirt just off of idle with negligible wheel spin, and a nice strong top end. I haven't messed with the PV adjuster.
Just for reference, new front fenders are around $40 - don't ask how I know.
Jeff and I did a 40 mile loop and started at MM4. Ran into 4 guys (one from montana) and one ATR rider.
Anyway, I wanted to really evaluate the Beta 300 as this was my second ride on it. (The first being last weekend). The motor is just the bomb. I can't say enough good things about what beta has done with it. Not sure if it's because they are a trials bike company....but they have the BEST offroad motor that I've ever riden! If any of you want to ride it, you're more than welcome! (except Frank)
The thing also turns like SOOOOOO good, It brings a smile to my face!
Some of the things I am working on is....It's not as stable as the KTM, I will probably push the forks down in the clamps a bit and also get a longer chain to puch the rear wheel back a bit.....may even take a turn out of the spring(rear) so that sag's down a little more.
A lot of the parts that were on my KTM 300 fit on here with either no or very little modification....like radiator gaurds, air filter, silencer, footpegs (MSR Softpegs are the best)!
Some other things that are will never fit are...pipe, any brake parts because they are Nissan.....by the way. I would say the brakes are as good in every way as the KTM's...which are (pretty darn good!)!
The overall components and way it was put together is very impressive and as good or better than the ktms and way better than the Japs! One thing they could do better is to put a spark arrestor on it and a little bigger gas tank!
But again....The MOTOR is what really seperates this bike from the rest! Its very electric and no (or little) vibration....Its awesome in every way!
Anyway, my next steps are to try an get it a tiny bit more stable...I will push the rear wheel back (get longer chain) and make it sag a tiny bit more with adjusting the shock spring.
